MicroLine ML4050 Color CCD Cooled Camera KAI-04050 (no shutter) [FLI-ML4050-C]
FLI-ML4050-C
$4,757.85 USD
Flight Lakes Instrumentation: MicroLine ML4050 Color CCD Cooled Camera KAI-04050 (no shutter)  - 2336 x 1752 Imaging Array 5.5 μm Pixel Size
3.7 x 3.7 x 4.8 inches the MicroLine is a small camera with big camera capabilities. Each component of the MicroLine camera is designed and manufactured for a long life in the most demanding conditions.
About MicroLine ML4050 Color CCD Cooled Camera KAI-04050 (no shutter) [FLI-ML4050-C]
ML4050 Sensor Specs
  • Sensor:    ON Semi KAI-04050
  • Pixels:    2336 x 1752
  • Pixel Size:    5.5 μm
  • Sensor Diagonal:    16 mm
  • Video Size (inch):    1.00
  • Anti Blooming:    300x
  • CCD Grades:    Standard
ML4050 Performance
  • Typical System Noise:    8e- RMS @ 4 MHz; 10e- RMS @ 12 MHz
  • Typical Dark Current:    <0.0002 electrons/pixel/sec @ -35ºC
  • Available Shutters:    Sensor has electronic shutter. Optional 25 mm
All MicroLine Cameras
  • Weight:    2.8 lbs (1.2 kg)
  • Interface:    USB 2.0
