MicroLine ML16070-1 Monochrome CCD Cooled Camera KAI-16070 Grade 1 Sensor (no shutter) [FLI-ML16070-1]
FLI-ML16070-1
$12,961.80 USD
Flight Lakes Instrumentation: MicroLine ML16070-1 Monochrome CCD Cooled Camera KAI-16070 Grade 1 Sensor (no shutter)  - 4896 x 3232 Imaging Array 7.4 μm Pixel Size
About MicroLine ML16070-1 Monochrome CCD Cooled Camera KAI-16070 Grade 1 Sensor (no shutter) [FLI-ML16070-1]
ML16070 Sensor Specs
  • Sensor:    ON Semi KAI-16070
  • Pixels:    4864 x 3232
  • Pixel Size:    7.4 μm
  • Full Well Capacity:    44,000 e-
  • Sensor Diagonal:    43.1 mm
  • Video Size (inch):    2.69
  • Anti Blooming:    1000x
  • CCD Grades:    1 or 2
ML16070 Performance
  • Typical System Noise:    8e- RMS @ 4 MHz; 10e- RMS @ 12 MHz
  • Typical Dark Current:    <0.002 electrons/pixel/sec @ -25ºC
All MicroLine Cameras
  • Weight:    4 lbs (1.8 kg)
  • Interface:    USB 2.0
