MicroLine ML16050-2 Monochrome CCD Cooled Camera KAI-16050 Grade 2 Sensor (no shutter) [FLI-ML16050-2]
FLI-ML16050-2
$7,847.85 USD
Flight Lakes Instrumentation: MicroLine ML16050-2 Monochrome CCD Cooled Camera KAI-16050 Grade 2 Sensor (no shutter)  - 4896 x 3264 Imaging Array 5.5 μm Pixel Size
About MicroLine ML16050-2 Monochrome CCD Cooled Camera KAI-16050 Grade 2 Sensor (no shutter) [FLI-ML16050-2]
ML16050 Sensor Specs
  • Sensor:    ON Semi KAI-16050
  • Pixels:    4896 x 3264
  • Pixel Size:    5.5 μm
  • Sensor Diagonal:    32.3 mm
  • Video Size (inch):    2.02
  • Anti Blooming:    300x
  • CCD Grades:    1 or 2
ML16050 Performance
  • Typical System Noise:    8e- RMS @ 4 MHz; 10e- RMS @ 12 MHz
  • Typical Dark Current:    <0.002 electrons/pixel/sec @ -25ºC
  • Available Shutters:    Sensor has electronic shutter. Optional 45 mm
All MicroLine Cameras
  • Weight:    2.8 lbs (1.3 kg)
  • Interface:    USB 2.0
