MicroLine ML29052-1 Color CCD Cooled Camera KAI-29052 Grade 1 Sensor (no shutter) [FLI-ML29052-C1]
FLI-ML29052-C1
$14,182.35 USD
Flight Lakes Instrumentation: MicroLine ML290502-1 Color CCD Cooled Camera KAI-29052 Grade 1 Sensor (no shutter) - 6576 x 4384 Imaging Array 5.5 μm Pixel Size
Overall, the KAI-29052 has 27% higher quantum efficiency than its predecessor, the KAI-29050. The KAI-29052 also has substantially lower readout noise than the KAI-29050
About MicroLine ML29052-1 Color CCD Cooled Camera KAI-29052 Grade 1 Sensor (no shutter) [FLI-ML29052-C1]
ML29052 Sensor Specs
  • Sensor:    ON Semi KAI-29050
  • Pixels:    6576 x 4384
  • Pixel Size:    5.5 μm
  • Sensor Diagonal:    43.4 mm
  • Video Size (inch):    2.71
  • Anti Blooming:    300x
  • CCD Grades:    1 or 2
ML29052 Performance
  • Typical System Noise:    4e- RMS @ 4 MHz; 8e- RMS @ 12 MHz
  • Typical Dark Current:    <0.002 electrons/pixel/sec @ -25ºC
All MicroLine Cameras
  • Weight:    4 lbs (1.8 kg)
  • Interface:    USB 2.0
