MicroLine ML4240F Monochrome CCD Cooled Camera CCD42-40-1-383 front illuminated with 45mm high speed shutter [FLI-ML4240-1-FI]
About MicroLine ML4240F Monochrome CCD Cooled Camera CCD42-40-1-383 front illuminated with 45mm high speed shutter [FLI-ML4240-1-FI]
Flight Lakes Instrumentation: MicroLine ML4240F Monochrome CCD Cooled Camera CCD42-40-1-383 front illuminated with 45mm high speed shutter - 2048 x 2048 Imaging Array 13.5 μm Pixel Size
ML4240-F Sensor Specs
- Sensor: E2V CCD42-40
- Pixels: 2048 x 2048
- Pixel Size: 13.5 μm
- Full Well Capacity: 100,000 e-
- Sensor Diagonal: 39.1 mm
- Video Size (inch): 2.4
- Anti Blooming: None
- Color Options: Monochrome
- CCD Type: Front Illuminated
- CCD Grades: Grade 1
ML4240-F Performance
- Digitization Speed: 700 KHz
- Typical System Noise: 11 e- RMS @ 700 KHz
- Typical Maximum Cooling: 58ºC Below Ambient (Liquid Cooled)
- Typical Dark Current: <0.25 e-/pixel/sec @ -35ºC
- Typical Non linearity: <1%
- Lens Mounts: Optional Nikon F-Mount or Canon EOS mount
- Available Shutters: 45 mm
All MicroLine Cameras
- Focal Plane to Faceplate: 21 mm (optical)
- Weight: 3.4 lbs.
- Interface: USB 2.0
- Remote Triggering: Standard
- Shutter MTBF: 1,000,000
