MicroLine ML1001 Monochrome CCD Cooled Camera KAF-1001 Grade 1 with 45mm shutter [FLI-ML1001-1]
FLI-ML1001-1
$11,694.90 USD
Flight Lakes Instrumentation: MicroLine ML1001 Monochrome CCD Cooled Camera KAF-1001 Grade 1 with 45mm shutter  - 1024 x 1024 Imaging Array 24 μm Pixel Size
The KAF-1001 sensor used in the ML1001 has two separate output amplifiers. One is designed for low noise and the other is designed for high full well capacity. The ML1001 has software-selectable high and low speed
readout for the low noise amplifier, and low speed readout for the high range amplifier. In high range mode, the dynamic range (addressable full well divided by read noise) is over 20,000:1, the highest of any sensor FLI sells.
The KAF-1001 also has excellent quantum efficiency in the near infrared (34% at 900nm) without the etaloning problems characteristic of backside illuminated sensors.
About MicroLine ML1001 Monochrome CCD Cooled Camera KAF-1001 Grade 1 with 45mm shutter [FLI-ML1001-1]
ML1001 Sensor Specs
  • Sensor:    ON Semi KAF-1001
  • Pixels:    1024 x 1024
  • Pixel Size:    24 μm
  • Full Well Capacity:    785,000 e-
  • Sensor Diagonal:    34.8 mm
  • Video Size (inch):    2.2
  • Anti Blooming:    None
  • CCD Grades:    1, 2
ML1001 Performance
  • Digitization Speed:    1 MHz, 3.4 MHz
  • Typical System Noise:    10e- @ 1 MHz; 15e- @ 3.4 MHz; 37e- (HR)
  • Typical Dark Current:    <0.02 e-/pixel/sec @ -35ºC
  • Typical Non linearity:    <1%
  • Available Shutters:    45 mm
All MicroLine Cameras
  • Weight:    3.0 lbs.
  • Interface:    USB 2.0
