MicroLine ML16000 Color CCD Cooled Camera KAI-16000 Grade 1 Sensor (no shutter) [FLI-ML16000-C1]
FLI-ML16000-C1
$10,628.85 USD
Flight Lakes Instrumentation: MicroLine ML16000 Color CCD Cooled Camera KAI-16000 Grade 1 Sensor (no shutter) - 4872 x 3248 Imaging Array 7.4 μm Pixel Size
The Kodak KAI-16000 is an interline transfer CCD offering 16 million pixels at up to 3 frames per second through 2 outputs. This image sensor is organized into an array of 4,872(H) x 3,248(V) with 7.4 micron square pixels and full 35mm optical format.
As an interline transfer CCD, the KAI-16000 includes additional features such as progressive scan readout, electronic shutter, low noise, high dynamic range, and blooming suppression. These features make the KAI-16000 the perfect sensor for applications in Industrial, Aerial, Security, and Scientific markets.
About MicroLine ML16000 Color CCD Cooled Camera KAI-16000 Grade 1 Sensor (no shutter) [FLI-ML16000-C1]
ML16000 Sensor Specs
  • Sensor:    ON Semi KAI-16000
  • Pixels:    4872 x 3248
  • Pixel Size:    7.4 μm
  • Full Well Capacity:    30,000 e-
  • Sensor Diagonal:    43.3
  • Video Size (inch):    2.7
  • Anti Blooming:    100x
  • CCD Grades:    1, 2
ML16000 PerformanceCamera Spec Sheet: PDF
  • Digitization Speed:    12 MHz
  • Typical System Noise:    6e- @ 1 MHz; 10e- @ 12 MHz
  • Typical Dark Current:    <0.002 e-/pixel/sec @ -25ºC
All MicroLine Cameras
  • Weight:    4 lbs (1.8 kg)
  • Interface:    USB 2.0
