MicroLine ML16000 Monochrome CCD Cooled Camera KAI-16000 Grade 1 Sensor (no shutter) [FLI-ML16000-1]
The Kodak KAI-16000 is an interline transfer CCD offering 16 million pixels at up to 3 frames per second through 2 outputs. This image sensor is organized into an array of 4,872(H) x 3,248(V) with 7.4 micron square pixels and full 35mm optical format.
As an interline transfer CCD, the KAI-16000 includes additional features such as progressive scan readout, electronic shutter, low noise, high dynamic range, and blooming suppression. These features make the KAI-16000 the perfect sensor for applications in Industrial, Aerial, Security, and Scientific markets.
About MicroLine ML16000 Monochrome CCD Cooled Camera KAI-16000 Grade 1 Sensor (no shutter) [FLI-ML16000-1]
Flight Lakes Instrumentation: MicroLine ML16000 Monochrome CCD Cooled Camera KAI-16000 Grade 1 Sensor (no shutter) - 4872 x 3248 Imaging Array 7.4 μm Pixel Size
ML16000 Sensor Specs
- Sensor: ON Semi KAI-16000
- Pixels: 4872 x 3248
- Pixel Size: 7.4 μm
- Full Well Capacity: 30,000 e-
- Sensor Diagonal: 43.3
- Video Size (inch): 2.7
- Anti Blooming: 100x
- Color Options: Monochrome or Color
- CCD Type: Interline Transfer
- CCD Grades: 1, 2
ML16000 PerformanceCamera Spec Sheet: PDF
- Digitization Speed: 12 MHz
- Typical System Noise: 6e- @ 1 MHz; 10e- @ 12 MHz
- Typical Maximum Cooling: 45ºC Below Ambient
- Typical Dark Current: <0.002 e-/pixel/sec @ -25ºC
- Non linearity: <1%
- Lens Mounts: Optional Nikon F-Mount or Canon EOS mount
- Available Shutters: Sensor has electronic shutter. Optional 65 mm
All MicroLine Cameras
- Focal Plane to Faceplate: 21 mm (optical)
- Weight: 4 lbs (1.8 kg)
- Interface: USB 2.0
- Remote Triggering: Standard
- Shutter MTBF: 1,000,000
