MicroLine ML16803 Monochrome CCD Cooled Camera KAF-16803 with 65mm Shutter & Copper Heatsink [FLI-ML16803CU]
FLI-ML16803CU
$12,894.85 USD
Flight Lakes Instrumentation: MicroLine ML16803 Monochrome CCD Cooled Camera KAF-16803 with 63.5mm Shutter  - 4096 x 4096 Imaging Array 9 μm Pixel Size
About MicroLine ML16803 Monochrome CCD Cooled Camera KAF-16803 with 65mm Shutter & Copper Heatsink [FLI-ML16803CU]
ML16803 Sensor Specs
Sensor: ON Semi KAF-16803
Pixels: 4096 x 4096
Pixel Size: 9 μm
Full Well Capacity: 100,000 e-
Sensor Diagonal: 52.1 mm
Video Size (inch): 3.3
Anti Blooming: > 100X saturation exposure
Color Options: Monochrome
CCD Type: Front Illuminated
CCD Grades: Standard
ML16803 Performance
Camera Spec Sheet: PDF
Status: In Production
Digitization Speed: 1 MHz, 8 MHz
Typical System Noise: 10e- @ 1 MHz; 16-e @ 8 MHz
Typical Maximum Cooling: 50ºC Below Ambient
Typical Dark Current: <0.01 e-/pixel/sec @ -30ºC
Typical Non linearity: <1%
Lens Mounts: Optional Nikon F-Mount or Canon EOS mount
Available Shutters: 65 mm
Housing Dimensions: 3.70 x 3.70 x 4.77 (94 x 94 x 121.3)
Focal Plane to Faceplate: 21 mm (optical)
Weight: 4.5 lbs. (2.03 kg)
All MicroLine Cameras
Interface: USB 2.0
Temperature Stability: 0.1ºC
Remote Triggering: Standard
Power: 12V (100-240V AC to 12V DC power supply included). With TEC off: <1A. TEC at 100%: 4.4A. (Optional Electromechanical Shutter open: 4A pulse for 100msec. Shutter held open, add 0.22A.)
Environment: -30ºC - 45ºC | 10% - 90% Relative Humidity
