ProLine PL11002 CCD Color Cooled Camera with KAI-11002M Grade 1 Sensor (no shutter) [FLI-PL11002-C1]
FLI-PL11002-C1
$9,804.85 USD
Flight Lakes Instrumentation: ProLine PL11000-2 CCD Color Cooled Camera with KAI-11002M Grade 1 Sensor (no shutter)   -  4008 X 2672 Array with 9 µm pixels
ProLine frame quality is second to none thanks to careful design,
implementation,and setup.
All cameras are assembled in our clean room under exacting conditions andmust pass a battery of tests before being shipped.
The Kodak KAI-11002 Image Sensor is a high-performance 11-million pixel sensor designed for professional digital still camera applications. The 9.0 mm square pixels with micro-lensing provides high sensitivity and the large full well capacity results in high dynamic range. The two high-speed outputs and binning capabilities allow for 1-3 frames per second (fps) video rate for the progressively scanned images. The vertical overflow drain structure provides anti-blooming protection and enables electronic shuttering for precise exposure control. Other features include low dark current, negligible lag and low smear.
KODAK KAI-11002 GRADE 1 SENSOR FEATURES
Total Number of Pixels: 4072 (H) x 2720 (V) = 11.1M Number of Effective Pixels: 4032 (H) x 2688 (V) = 10.8M Number of Active Pixels: 4008 (H) x 2672 (V) = 10.7M Number of Outputs: 1 or 2 - Dynamic Range: 66 dB Pixel Size: 9.0 mm (H) x 9.0 mm (V) Imager Size: 43.3mm (diagonal) Chip Size: 37.25mm (H) x 25.70mm (V) Aspect Ratio: 3:2 Saturation Signal: 60,000 electrons Maximum Data Rate: 28 MHz Output Sensitivity: - 13 V/e- Total Noise: 30 electrons Dark Current: < 50 mV/s Dark Current Doubling Temperature: 7ºC Charge Transfer Efficiency: > 0.99999 Blooming Suppression: > 1000X Smear: < -80 dB Image Lag: < 10 electrons High resolution - High sensitivity - High dynamic range Low noise architecture - High frame rate Binning capability for higher frame rate - Electronic shutter
About ProLine PL11002 CCD Color Cooled Camera with KAI-11002M Grade 1 Sensor (no shutter) [FLI-PL11002-C1]
  • Total Number of Pixels: 4072 (H) x 2720 (V) = 11.1M
  • Number of Effective Pixels: 4032 (H) x 2688 (V) = 10.8M
  • Number of Active Pixels: 4008 (H) x 2672 (V) = 10.7M
  • Number of Outputs: 1 or 2 - Dynamic Range: 66 dB
  • Pixel Size: 9.0 mm (H) x 9.0 mm (V)
  • Imager Size: 43.3mm (diagonal)
  • Chip Size: 37.25mm (H) x 25.70mm (V)
  • Aspect Ratio: 3:2
  • Saturation Signal: 60,000 electrons
  • Maximum Data Rate: 28 MHz
  • Output Sensitivity: - 13 V/e-
  • Total Noise: 30 electrons
  • Dark Current: < 50 mV/s
  • Dark Current Doubling Temperature: 7ºC
  • Charge Transfer Efficiency: > 0.99999
  • Blooming Suppression: > 1000X
  • Smear: < -80 dB
  • Image Lag: < 10 electrons
  • High resolution - High sensitivity - High dynamic range
  • Low noise architecture - High frame rate
  • Binning capability for higher frame rate - Electronic shutter
PL11002 Sensor Specs
  • Pixels:    4008 x 2672
  • Pixel Size:    9 μm
  • Sensor Diagonal:    43.3 mm
  • Video Size (inch):    2.7
  • Anti Blooming:    1000x
  • CCD Grades:    0, 1, 2
PL11002 Performance
  • Digitization Speed:    1 MHz and 12 MHz
  • Typical System Noise:    9e- @ 1 MHz; 16e- @ 12 MHz
  • Typical Dark Current :    <.005 e-/pixel/sec @ -30ºC
All ProLine Cameras
  • Interface:    USB 2.0
