ProLine PL11002 CCD Color Cooled Camera with KAI-11002M Grade 0 Sensor (no shutter) [FLI-PL11002-C0]
FLI-PL11002-C0
$13,337.75 USD
Flight Lakes Instrumentation: ProLine PL11002 CCD Color Cooled Camera with KAI-11002M Grade 0 Sensor (no shutter)   -  4008 X 2672 Array with 9 µm pixels
The Kodak Interline KAI-11002 Image Sensor is a high-performance 11-million pixel sensor designed for professional digital still camera applications. The 9.0 µm square pixels with microlenses provide high sensitivity and the large full well capacity results in high dynamic range. The two high-speed outputs and binning capabilities allow for 1-3 frames per second (fps) video rate for the progressively scanned images.
The vertical overflow drain structure provides antiblooming protection and enables electronic shuttering for precise exposure control. Other features include low dark current, negligible lag and low smear. When you choose this sensor, you choose to get high resolution, high sensitivity, high dynamic range, low noise architecture, high frame rate, binning capability for higher frame rate and electronic shutter.
About ProLine PL11002 CCD Color Cooled Camera with KAI-11002M Grade 0 Sensor (no shutter) [FLI-PL11002-C0]
PL11002 Sensor Specs
  • Pixels:    4008 x 2672
  • Pixel Size:    9 μm
  • Sensor Diagonal:    43.3 mm
  • Video Size (inch):    2.7
  • Anti Blooming:    1000x
  • CCD Grades:    0, 1, 2
PL11002 Performance
  • Digitization Speed:    1 MHz and 12 MHz
  • Typical System Noise:    9e- @ 1 MHz; 16e- @ 12 MHz
  • Typical Dark Current :    <.005 e-/pixel/sec @ -30ºC
All ProLine Cameras
  • Interface:    USB 2.0
