MicroLine ML2020 Color CCD Cooled Camera KAI-2020 (no shutter) Copy [FLI-ML2020-C]
FLI-ML2020-C
$4,891.75 USD
Flight Lakes Instrumentation: MicroLine ML2020 Color CCD Cooled Camera KAI-2020 (no shutter) - 1600 x 1200 Imaging Array 7 μm Pixel Size
3.7 x 3.7 x 4.8 inches the MicroLine is a small camera with big camera capabilities. Each component of the MicroLine camera is designed and manufactured for a long life in the most demanding conditions.
The ML2020 CCD camera features the Interline Kodak KAI-2020 Double TEC Sensor. Fully field-serviceable and hermetically sealed from dust and moisture. The FLI MicroLine CCD Camera utilizes an internal frame buffer, thus allowing an image to be quickly read out and downloaded to the PC. CCD can be operated at -30° deg C with typical room temperatures and without the need for special cooling sequences. CNC machined with only the highest quality electrical components. Compatible with all FLI imaging accessories, including the Precision line of Color Filter Wheels and Digital Focusers. Options for the ML2020 include mechanical shutters, Anti-Dew Technology & liquid cooling. A variety of mechanical shutters are available optionally. Contact us for details. MicroLine CCD cameras are smaller and lighter-weight than the competition, but outperforms them in key areas such as noise, frame quality, download speeds, bit-depth, and CCD cooling. FLI MicroLine CCD cameras feature fast download speeds that simply leave the competition behind. Each component of the FLI MicroLine camera is designed and manufactured for a long life in the most demanding conditions. All major components are CNC machined and you’re looking at only the highest quality electrical components and circuit boards with logo, serial number and focal plane indicators laser-etched on the surface – not printed. FLI designed photo-etched stainless-steel shutters are field-serviceable should they ever encounter damage and the sensor is hermetically sealed from dust and moisture. What sets FLI MicroLine CCD Cameras apart is their small form factor. At 3.7 x 3.7 x 5 inches (HWL), the FLI MicroLine is a small camera with big camera capabilities! The Microline improves upon the highly successful FLI MaxCam design in a number of key areas including cooling, download speeds, clear aperture, and sensor capability. The FLI MicroLine’s robust cooling design achieves a sustainable cooling performance of 50-55° deg C below ambient. The camera’s CCD can be operated at -30° deg C with typical room temperatures and without the need for water cooling (sold separately). Conventional imaging cameras move the image data directly from the image sensor to the USB port, making them susceptible to added artifacts due to PC processing tasks, processor speed, and other PC-related issues. The MicroLine avoids these issues with its internal frame buffer, thus allowing an image to be quickly read out and downloaded to the PC. This allows the PC to take the image at whatever speed it is capable of without introducing any artifacts to the image. When it comes the FLI MicroLine, you get system compatibility and mounting options as well as mechanical shutter, liquid cooling, and Anti-Dew Technology options that will help you trick out your camera the way you want it. The MicroLine line of CCD cameras is compatible with all FLI imaging accessories, including the Precision line of Color Filter Wheels and Digital Focusers. MicroLine camera adapters are available for microscope, telescope and machine vision connectivity.
About MicroLine ML2020 Color CCD Cooled Camera KAI-2020 (no shutter) Copy [FLI-ML2020-C]
ML2020 Sensor Specs
  • Sensor:    ON Semi KAI-2020
  • Pixels:    1600 x 1200
  • Pixel Size:    7.4 μm
  • Full Well Capacity:    40,000 e-
  • Sensor Diagonal:    14.8
  • Video Size (inch):    0.9
  • Anti Blooming:    300x
  • CCD Grades:    Standard
ML2020 Performance
  • Digitization Speed:    12 MHz
  • Typical System Noise:    9 e- RMS @ 12 MHz
  • Typical Dark Current:    <0.009 e-/pixel/sec @ -35ºC
  • Available Shutters:    Sensor has electronic shutter. Optional 25 mm
All MicroLine Cameras
  • Weight:    2.8 lbs
  • Interface:    USB 2.0
