MicroLine ML11002 Monochrome CCD Cooled Camera KAI-11002 Grade 0 Sensor (no shutter) [FLI-ML11002-0]
FLI-ML11002-0
$12,565.25 USD
Flight Lakes Instrumentation: MicroLine ML11002 Monochrome CCD Cooled Camera KAI-11002 Grade 0 Sensor (no shutter) - 4008 x 2672 Imaging Array 9 μm Pixel Size
About MicroLine ML11002 Monochrome CCD Cooled Camera KAI-11002 Grade 0 Sensor (no shutter) [FLI-ML11002-0]
ML11002 Sensor Specs
  • Pixels:    4008 x 2672
  • Pixel Size:    9 μm
  • Sensor Diagonal:    43.3
  • Video Size (inch):    2.7
  • Anti Blooming:    1000x
  • CCD Grades:    0, 1, 2
ML11002 Performance
  • Digitization Speed:    16 bits @ 2 MHz and 12 MHz
  • Typical System Noise:    9 e- @ 2 MHz; 14 e- RMS @ 12 MHz
  • Typical Dark Current:    <0.004 e-/pixel/sec @ -30ºC
All MicroLine Cameras
  • Weight:    4 lbs (1.8 kg)
  • Interface:    USB 2.0
