MicroLine ML09000 Monochrome CCD Cooled Camera KAF-09000 with 63.5mm shutter [FLI-ML09000]
FLI-ML09000
$11,349.85 USD
Flight Lakes Instrumentation: MicroLine ML09000 Monochrome CCD Cooled Camera KAF-09000 with 63.5mm shutter  - 3056 x 3056 Imaging Array 12 μm Pixel Size
About MicroLine ML09000 Monochrome CCD Cooled Camera KAF-09000 with 63.5mm shutter [FLI-ML09000]
ML09000 Sensor Specs
  • Sensor:    ON Semi KAF-09000
  • Pixels:    3056 x 3056
  • Pixel Size:    12 μm
  • Full Well Capacity:    110,000 e-
  • Sensor Diagonal:    51.9 mm
  • Video Size (inch):    3.3
  • Anti Blooming:    > 100X saturation exposure
  • CCD Grades:    Standard
ML09000 Performance
  • Digitization Speed:    1 MHz, 8 MHz
  • Typical System Noise:    11e- @ 1 MHz; 16e- @ 8 MHz
  • Typical Maximum Cooling:    50ºC Below Ambient
  • Typical Dark Current:    <0.03 e-/pixel/sec @ -30ºC
  • Typical Non linearity:    <1%
All MicroLine Cameras
  • Weight:    4.5 lbs. (2.03 kg)
  • Interface:    USB 2.0
