MicroLine ML50100 Monochrome CCD Cooled Camera KAF-50100 with 65mm shutter [FLI-ML50100]
FLI-ML50100
$16,499.85 USD
Flight Lakes Instrumentation: MicroLine ML50100 Monochrome CCD Cooled Camera KAF-50100 with 65mm shutter - 8176 x 6132 Imaging Array 6 μm Pixel Size
The new microlensed KAF-50100 is the result of a yearlong collaborative effort between ON Semiconductor and Finger Lakes Instrumentation. Our goal: to create a sensorwith both extremely high resolution and excellent quantum efficiency (QE).
The significantly boosted QE of the new KAF-50100 sensor brings it in line with popular full frame sensors such as the KAF-16803 and KAF-8300 but with
much higher spatial resolution.
At 5" diameter in the front and less than 5" front to back, the ML50100 is a small camera with big camera capabilities. Each component of the camera is designed and manufactured for a long life in the most demanding conditions. The MicroLine ML50100 can cool to 45C below ambient in less than five minutes. Simply set the MicroLine cooling where you want it and the camera will do the rest, quickly and without worries.
About MicroLine ML50100 Monochrome CCD Cooled Camera KAF-50100 with 65mm shutter [FLI-ML50100]
ML50100 Sensor Specs
  • Sensor:    ON Semi KAF-50100
  • Pixels:    8176 x 6132
  • Pixel Size:    6 μm
  • Full Well Capacity:    40,300 e-
  • Sensor Diagonal:    61.3 mm
  • Video Size (inch):    3.8
  • Anti Blooming:    800x
  • CCD Grades:    Standard
ML50100 Performance
  • Digitization Speed:    2 channels at 8 MHz each
  • Typical System Noise:    12 e- RMS @ 8 MHz
  • Typical Dark Current:    0.015 e-/pixel/sec @ -25ºC
  • Typical Non linearity:    <1%
All MicroLine Cameras
  • Housing Dimensions:    5.067 dia. x 4.98 (128.7 mm dia. x 126.6 mm)
  • Weight:    4.3 lbs. (1.94 kg)
  • Interface:    USB 2.0
