MicroLine ML4022 Monochrome CCD Cooled Camera KAI-4022 (no shutter) [FLI-ML4022]
FLI-ML4022
$5,684.85 USD
Flight Lakes Instrumentation: MicroLine ML4022 Monochrome CCD Cooled Camera KAI-4022 (no shutter) - 2048 x 2048 Imaging Array 7.45 μm Pixel Size
High quantum efficiency and exceptionally low read noise give the ML4022 sensitivity down to microlux from visible to the near infrared. High spatial resolution makes the ML4022 ideal for low light applications such as fluorescence.
Standard configuration: single channel with software selectable download speeds: 1.5 MHz for exceptionally low noise, and 12 MHz (about 2 frames per second).
Optional configuration: 2 channels at 12 MHz each (about 4 frames per second)
Air cooling to 60°C below ambient. Optional liquid circulation for cooling to 80°C below ambient. Standard C-mount thread or optional FLI dovetail for use
with a variety of adapters, such as Nikon F-mount or Canon EOS.
About MicroLine ML4022 Monochrome CCD Cooled Camera KAI-4022 (no shutter) [FLI-ML4022]
ML4022 Sensor Specs
  • Sensor:    ON Semi KAI-4022
  • Pixels:    2048 x 2048
  • Pixel Size:    7.4 μm
  • Full Well Capacity:    40,000 e-
  • Sensor Diagonal:    21.4
  • Video Size (inch):    1.3
  • Anti Blooming:    300x
  • CCD Grades:    Standard
ML4022 Performance
  • Digitization Speed:    12 MHz
  • Typical System Noise:    9 e- RMS @ 12 MHz
  • Typical Dark Current:    <0.03 e-/pixel/sec @ -30ºC
  • Lens Mounts:    Optional Micro 4/3, Nikon F-Mount or Canon EOS mount
  • Available Shutters:    Sensor has electronic shutter. Optional 25 or 45 mm
All MicroLine Cameras
  • Weight:    2.8 lbs
  • Interface:    USB 2.0
