MicroLine MLX285 Monochrome CCD Cooled Camera Sony ICX285 (no shutter) [FLI-MLX285]
At 3.7 x 3.7 x 4.8 inches the MicroLine is a small camera with big camera capabilities. Each component of the MicroLine camera is designed and manufactured for a long life in the most demanding conditions.
The MLx285 hardware can be configured for microsecond or millisecond exposure resolution. When set up for microsecond timing, the exposure range is 100 microseconds to 35 minutes. When set up for millisecond timing, the exposure range is 1 millisecond to 24 days
About MicroLine MLX285 Monochrome CCD Cooled Camera Sony ICX285 (no shutter) [FLI-MLX285]
Flight Lakes Instrumentation: MicroLine MLX285 Monochrome CCD Cooled Camera Sony ICX285 (no shutter) - 1360 x 1024 Imaging Array 6.45 μm Pixel Size
MLx285 Sensor Specs
- Sensor: Sony ICX285AL
- Pixels: 1360 x 1024
- Pixel Size: 6.45 μm
- Full Well Capacity: 18,000 e-
- Sensor Diagonal: 11.2
- Video Size (inch): 0.7
- Anti Blooming: Yes
- Color Options: Monochrome
- CCD Type: Interline Transfer
- CCD Grades: Standard
MLx285 Performance
- Digitization Speed: 7 MHz
- Typical System Noise: 4.5 e- RMS @ 7 MHz
- Typical Maximum Cooling: 60ºC Below Ambient
- Typical Dark Current: <0.002 e-/pixel/sec @ -35ºC
- Non linearity: <1%
- Lens Mounts: C-Mount; Optional Nikon F-Mount or Canon EOS mount
- Available Shutters: Sensor has electronic shutter. Optional 25 mm
All MicroLine Cameras
- Focal Plane to Faceplate: 15.7 mm (optical)
- Weight: 2.8 lbs
- Interface: USB 2.0
- Remote Triggering: Standard
- Shutter MTBF: 1,000,000
