ProLine PL77-1-MB CCD Monochrome Cooled Camera with E2V 77 Grade 1 Midband Sensor and 63.5 mm Shutter [FLI-PL77-1-MB]
FLI-PL77-1-MB
$13,718.85 USD
Flight Lakes Instrumentation: ProLine PL77-1-MB CCD Monochrome Cooled Camera with E2V 77 Grade 1 Midband Sensor and 63.5 mm Shutter -  512 x 512 Array with 24 µm pixels
This version of the CCD77 family of sensors has full-frame architecture. Back illumination technology, in combination with extremely low noise amplifiers, makes the device well suited to the most demanding scientific applications. To improve the sensitivity further, the CCD is manufactured without anti- blooming structures.
This device has a single serial output register. Separate charge detection circuits are incorporated at each end of the register, which is split so that a line of charge can be transferred to either output, or split between the two.
The register is provided with a drain and control gate along the outer edge of the channel for charge dump purposes. The sensor is made using e2v technologies. Advanced Inverted Mode process to minimize dark current, allowing the device to be operated with extended integration periods and minimal cooling.
About ProLine PL77-1-MB CCD Monochrome Cooled Camera with E2V 77 Grade 1 Midband Sensor and 63.5 mm Shutter [FLI-PL77-1-MB]
PL77 Midband Sensor Specs
  • Sensor:    e2v CCD77-00-1-358
  • Pixels:    512 x 512
  • Pixel Size:    24 μm
  • Full Well Capacity:    350,000 e-
  • Sensor Diagonal:    17.4 mm
  • Video Size (inch):    1.1
  • Anti Blooming:    None
  • CCD Grades:    Grade 1
PL77 Midband PerformanceCamera Spec Sheet: PDF
  • Digitization Speed:    1.8 MHz, 650 kHz (up to 3.6 MHz available)
  • Typical System Noise:    11 e- RMS @ 650 kHz
  • Typical Maximum Cooling:    65ºC Below Ambient
  • Typical Dark Current:    <0.8 e-/pixel/sec @ -45ºC
All ProLine Cameras
  • Interface:    USB 2.0>
