ProLine PL16801 Monochrome CCD Cooled Camera KAF-16801E Grade 1 with 63.5 mm Shutter [FLI-PL16801-1]
FLI-PL16801-1
$34,427.00 USD
Flight Lakes Instrumentation: ProLine PL16801 Monochrome CCD Cooled Camera KAF-16801E Grade 1 with 63.5 mm Shutter -  4096 x 4096 Imaging Array 9 μm Pixel Size
The Truesense KAF-16801 is a high performance image sensor with 4096 H x 4096 V photo active pixels designed for a wide range of image sensing applications. The sensor incorporates true two-phase CCD technology, simplifying the support circuits required to drive the sensor as well as reducing dark current without compromising charge capacity. The sensor also utilizes the Truesense Transparent Gate Electrode to improve sensitivity compared to the use of a standard front side illuminated polysilicon electrode.
About ProLine PL16801 Monochrome CCD Cooled Camera KAF-16801E Grade 1 with 63.5 mm Shutter [FLI-PL16801-1]
PL16801 Sensor Specs
  • Sensor:    ON Semi KAF-16801
  • Pixels:    4096 x 4096
  • Pixel Size:    9 μm
  • Full Well Capacity:    110,000 e-
  • Sensor Diagonal:    52.1 mm
  • Video Size (inch):    3.3
  • Anti Blooming:    None
  • CCD Grades:    1, 2
PL16801 Performance
  • Digitization Speed:    1 MHz, 8 MHz
  • Typical Dark Current:    <0.04 e-/pixel/sec @ -35ºC
All ProLine Cameras
  • Interface:    USB 2.0
