ProLine PL1001 Monochrome CCD Cooled Camera KAF-1001E Grade 1 with 63.5 mm Shutter [FLI-PL1001-1]
FLI-PL1001-1
$12,209.90 USD
Flight Lakes Instrumentation: ProLine PL1001E Monochrome Grade 1 CCD Camera with 63.5 Shutter -  1024 x 1024 Imaging Array 24 μm Pixel Size
The Truesense KAF-1001E is a 22.5mm diagonal (Type 4/3) high performance color full-frame CCD (charge-coupled device) image sensor designed for a wide range of color image sensing applications including digital imaging. Each pixel contains blooming protection by means of a lateral overflow drain thereby preventing image corruption during high light level conditions. Each of the 5.4mm square pixels are patterned with an RGB mosaic color filter with overlying microlenses for improved color response and reproduction. A border of buffer and light-shielded pixels surrounds the photoactive pixels.
About ProLine PL1001 Monochrome CCD Cooled Camera KAF-1001E Grade 1 with 63.5 mm Shutter [FLI-PL1001-1]
PL1001 Sensor Specs
  • Sensor:    ON Semi KAF-1001E
  • Pixels:    1024 x 1024
  • Pixel Size:    24 μm
  • Full Well Capacity:    500,000 e-
  • Sensor Diagonal:    34.8 mm
  • Video Size (inch):    2.2
  • Anti Blooming:    None
  • CCD Grades:    1, 2
PL1001 Performance
  • Digitization Speed:    1 MHz, 3.3 MHz
  • Typical Dark Current:    <0.2 e-/pixel/sec @ -45ºC
All ProLine Cameras
  • Interface:    USB 2.0
