ProLine PL09000 Monochrome CCD Cooled Camera with 63.5 mm Shutter [FLI-PL09000]
FLI-PL09000
$11,349.85 USD
Flight Lakes Instrumentation: ProLine PL09000 Monochrome CCD Camera with 63.5 mm Shutter Cooled Camera -  3056 x 3056 Imaging Array 12 μm Pixel Size
ProLine frame quality is second to none thanks to careful design,
implementation,and setup.
About ProLine PL09000 Monochrome CCD Cooled Camera with 63.5 mm Shutter [FLI-PL09000]
PL09000 Sensor Specs
  • Sensor:    ON Semi KAF-09000
  • Pixels:    3056 x 3056
  • Pixel Size:    12 μm
  • Full Well Capacity:    110,000 e-
  • Sensor Diagonal:    51.9 mm
  • Video Size (inch):    3.3
  • Anti Blooming:    > 100X saturation exposure
  • CCD Grades:    Standard
PL09000 Performance
  • Digitization Speed:    1 MHz, 8 MHz
  • Typical System Noise:    10e- @ 1 MHz; 15e- @ 8 MHz
  • Typical Dark Current:    <0.02 e-/pixel/sec @ -35ºC
All ProLine Cameras
  • Interface:    USB 2.0
