ZWO ASI094MC Pro Color astronomy camera. [ZWO-ASI094MCPRO]
ZWO-ASI094MCPRO
(0 reviews)
$3,999.00 USD
ZWO Optical: ASI094MC Pro camera integrates Sony IMX094 full-frame sensor (36 mm x 24 mm). It is ZWO first full-frame cooled camera. This camera has 7376 x 4928 pixels, and supports BIN2, BIN3, BIN4 mode. The pixel size is 4.88 μm x 4.88 μm.  This camera provides 14bit ADC and its full well is 52000e.
DDR Memory Buffer
ASI094 Pro camera includes one 256MB DDR3 memory buffer to help data transfer more stable and  no amp-glow issue which is caused by the slow speed data transfer during reading out under USB2.0 Port.
Astrophotography Performance
ASI094 Pro offers very good performance for astrophotography. Low read noise, high dynamic range, QE peak 56% and much more.
USB 3.0 Port & USB2.0 HUB
USB 3.0 Port: can provide 5Gb bandwidth to let ASI094 Pro run at  5 fps at full resolution(36Mega).
ASI094 Pro camera has one full frame sensor, so the power consumption (650mA@5V) is much higher than other cameras. But USB3.0 can provide 1000mA current, so ASI094 Pro can run standalone under USB3.0 host, it doesn’t need external power supply.
You need to connect the external 12v power supply if you connect the camera to USB 2.0 host which can only provide 500ma current.
we recommends 12V at 3A or more DC adapter for cooler power supply(2.1*5.5, center positive)
Battery from 9-15V is also suitable for cooler power supply
USB 2.0 HUB: can connect with various accessories, such as filter wheel, guide camera and electronic focuser, so you can manage your cable better with USB2.0 hub. There are 2 short 0.5m USB2.0 cable come with ASI094 Pro. the power of hub source from external power supply if you connect it.
Cooling and Anti-Dew Heater
ASI094 Pro has 2 stage TEC cooling system to enable very deep cooling (-35℃ below ambient). you need external power supply to power on the cooler. AC-DC power adapter is not included in this package, you can order from here.
The anti-dew heater can heat the protect window to avoid any dew problem happens, the heat power is around 6W and can be turn off  in software to save power.
What is in the box?
ASI094 Pro box includes all necessary cables, drivers, adapters, and manuals.
About ZWO ASI094MC Pro Color astronomy camera. [ZWO-ASI094MCPRO]
DDR Memory Buffer
What is in the box?
