Rigel Quik Finder Heater [AZ-722]
AZ-722
$44.15 USD
Astrozap: Now you'll never have to worry about your Rigel finder dewing over again! This U-shaped Telrad Dew Heater from Astrozap wraps securely over the viewing window and doesn't obstruct the view.
When running a full power, the AstroZap Dew Heater draws 0.88 amps and much less when operating in a normal mode. The heater comes with a four-foot cord and phono-plug connector for 12-volt operation. But remember, the AstroZap Rigel Dew Buster is just the heater and cord... You'll need a dew system controller to supply the power. No worries! The AstroZap AstroStrap Dew Heater is compatible with Astrozap, Kendrick, Dew Buster, Orion, and Thousand Oaks Controllers.
When you use an AstroZap AstroStrap the HEAT is on!
Keep the dew off the viewing window of your Rigel Quick Finder! The AstroZap AstroStrap Rigel Dew Heater is a U-shaped heater that fits nicely over the viewing window of the popular Rigel finder, and is designed so that it stays in place and does not obstruct your view. Permanently attached 4 power cord with a male RCA plug end. The AstroZap AstroStrap Rigel Dew Heater is compatible with Kendrick, Thousand Oaks and Orion Controllers. Non-marring velcro and elastic fixtures. Connects to an available port on a "dew system controller" sold separately.
About Rigel Quik Finder Heater [AZ-722]
  • Keep the dew off the viewing window of your Rigel Quick Finder!
  • The AstroZap AstroStrap Rigel Dew Heater is a U-shaped heater that fits nicely over the viewing window of the popular Rigel finder, and is designed so that it stays in place and does not obstruct your view.
  • Permanently attached 4 power cord with a male RCA plug end.
  • The AstroZap AstroStrap Rigel Dew Heater is compatible with Kendrick, Thousand Oaks and Orion Controllers.
  • Non-marring velcro and elastic fixtures.
  • Connects to an available port on a "dew system controller" sold separately.
