iOPTRON Lithium-Poly Battery for SkyTracker Pro [IO-3329]
IO-3329
$14.39 USD $20.55 USD
2 in stock On sale IN STOCK, usually ships within 48h or less directly from our Canadian warehouse
IOptron: Replacement Lithium-Poly (Lipo) rechargeable battery for iOptron SkyTracker Pro mount.
Features:
Assemble with high quality 3.7V Li-Poly rechargeable battery pack Capacity 2000mAh Voltage 3.7V, peak at 4.2V No memory effect Built-in IC chip will prevent battery pack from over charge, over discharge and prolongs battery life WARNING:
Li-Poly battery is very sensitive to charging characteristics and may explored or burn if mishandled Charge only use a charger designed for this battery Do not charge the battery below 0C Do not dispose in a fire Disposal the battery according your government regulation
About iOPTRON Lithium-Poly Battery for SkyTracker Pro [IO-3329]
Features:
  • Assemble with high quality 3.7V Li-Poly rechargeable battery pack
  • Capacity 2000mAh
  • Voltage 3.7V, peak at 4.2V
  • No memory effect
  • Built-in IC chip will prevent battery pack from over charge, over discharge and prolongs battery life
WARNING:
  • Li-Poly battery is very sensitive to charging characteristics and may explored or burn if mishandled
  • Charge only use a charger designed for this battery
  • Do not charge the battery below 0C
  • Do not dispose in a fire
  • Disposal the battery according your government regulation
  • Battery type:    Lithium-Poly rechargeable battery
  • Capacity:    2000 mAh
  • Output voltage:    3.7V (peak at 4.2V)
  • Dimensions:    0.33"X1.34"X2.00" (8.5 X 34 X 51 mm)
  • Weight:    1.1 oz (32g)
  • Charging voltage:    <4.2V
  • Warranty:    30 days limited
