Baader T-2 Extension Tube (15mm long) [BA-T2-25A]
BA-T2-25A
$23.00 USD
Baader: Baader Astro T-2 System™ Component Chart For over 30 years we have focused on the Astro T-2 thread system (M 42 x 0.75 mm); virtually every telescope manufacturer must offer this thread far ahead of the focal point of his instrument, such a universal T-ring (for DSLR cameras) can be connected. The only exceptions are (still) Russian equipment, there the thread diameter is the same, but the pitch is still 1mm per revolution - rather than 0.75mm! Therefore, we offer among other things a "Russians adapter". At only 7mm additional optical length it can allow so many Russian lenses or telescopes to be compatible with an international Astro T-2 (M 42 x 0.75mm) connector! For the sake of better recognition mostly are marked. See marking small 'a' or small 'i' in the respective indication! "a"; identifies an external thread (male); or, if Ø sign which a diameter, "i"; - a female is always (female) or - Ø character - an inner diameter.   The Optical Length A small selection from the variety of products from the Baader Astro T-2 System™
15mm optical path length Telescope side T-2 internal thread Focus side T-2 external thread For eyepiece projection with shift/sliding focuser
About Baader T-2 Extension Tube (15mm long) [BA-T2-25A]
  • 15mm optical path length
  • Telescope side T-2 internal thread
  • Focus side T-2 external thread
  • For eyepiece projection with shift/sliding focuser
  • SKU (#)    1508154
  • WEIGHT (KG)    0.031
  • OPTICAL TUBE LENGTH    15
  • T-2 PART #    25A
  • USAGE    for eyepiece projection with sliding focuser
  • INNER DIAMETER / CLEAR APERTURE (MM)    38
  • OUTER DIAMETER    46
  • INNER CONNECTION (LENS SIDED)    Thread, T-2 (M42 x 0,75)
  • OUTER CONNECTION (EYEPIECE/-CAMERA-SIDED)    Thread, T-2 (M42 x 0,75)
  • COMPATIBLE BRANDS    Astro T-2, Baader Planetarium
  • TYPE OF ADAPTER    Extension
