Professional PLB resin “Flight-Case” GM2000 HPS II COMBI / ULTRAPORT [10M-2063H]
10M-2063H
$2,204.20 CAD
0 in stock specialorder
Set of three special PLB resin cases, for GM2000 HPS II Ultraport / Combi mounts: two trolley style case accommodate the mount and a hand case accommodates the counterweights, the electronic parts and other.
Taking care of your GM2000 mount will assure several years of great performances; the Professional cases PLB ensure a very high level of protection. These made in Italy cases are made of a special resins compound which offers a combination of high elasticity,  increased shock absorption, reduced transport weight and resistance against temperature extremes. They also ensure a perfect barrier against dust, humidity, sand, ashes.  The Internal padding is perfectly shaped to accommodate the instruments. Two cases, with a trolley configuration, contain the GM2000  Combi or Ultraport mount; the other one contains the counterweights and shaft , the electronic parts (control box + hand controls and cables); eventually  other accessories can still fit
NOTE: This item *must* be purchased with a mount. Without a mount, the cost of shipping empty cases from Italy runs north of 1,200 euros alone, and this cost will be charged to the customer. Sorry, there is no way around this shipping cost.
About Professional PLB resin “Flight-Case” GM2000 HPS II COMBI / ULTRAPORT [10M-2063H]
Dimensions mm: 2x 550 x 460 x 260 mm and 360 x 480 x 220 mm
Dimensions in: 2x 21.6” x 18.1” x 10.2”  and 14.2” x 18.9” x 8.7”
Material: special resins compound
Made in Italy
