Lateral double 3" plate "Lodual" with fixed center holder #10M2130 and 2 pcs #10M2085 clamping plates [10M-2105]
0 in stock specialorder
This special double plate is designed to allow a parallel mounting of two optical tubes on the 10Micron mounts. The bottom slide is a standard 3” dovetail bar (Losmandy compatible) #10M2130; the clamping plates are two 3” Losmandy compatible (#10M2085). All the components are CNC machined, black anodized aluminum. They are 3 different possible distances between the two clamps: appr. 210, 245 and 281mm (8.3”, 9.6”, 11”).
Notes:
– The GM1000 HPS Mount needs the #10M1105 Adapter in order to mantain the corret encoder’s position references
– All the other mounts require a #10M2085 or #10M2185 3″ Losmandy clamping plate.
Included items:
Bottom dovetail 3” Losmandy (#10M2130), 400mm lenght Nr.2 x 3” clamps #10M2085, Losmandy compatible (all the components are pre-assembled and aligned)
About Lateral double 3" plate "Lodual" with fixed center holder #10M2130 and 2 pcs #10M2085 clamping plates [10M-2105]
10Micron: Fixed mounting plate "Lodual" including two 3" clamps #10M2085, for parallel mounting of two optical tubes.
Notes:
Included items:
- Bottom dovetail 3” Losmandy (#10M2130), 400mm lenght
- Nr.2 x 3” clamps #10M2085, Losmandy compatible (all the components are pre-assembled and aligned)
