FOCs Kit Avalon for OTA GSO 6" & 8" [AV-FOCSGSO68]
AV-FOCSGSO68
$293.59 USD
Avalon Instruments: FOCs Kit Avalon for OTA GSO 6" & 8": This new kit can be used ONLY with the StarGO simply connecting it to one of the the AUX port with the new focuser Ascom driver
Avalons FOCs Focuser system is a top notch example of precision hardware. This model is for use with the TPO 8" or 6" Telescopes. Like Avalon Mounts, the FOCs uses a belt system that has no play or wear when in use for smooth manipulation. It also uses a stepper motor that allows high resolution positioning and can be controlled directly by the StarGo via the AUX1 port or by the new X-MD control system that allows a stand-alone functionality thanks to the integrated battery.
About FOCs Kit Avalon for OTA GSO 6" & 8" [AV-FOCSGSO68]
  • Avalons FOCs Focuser system is a top notch example of precision hardware. This model is for use with the TPO 8" or 6" Telescopes.
  • Like Avalon Mounts, the FOCs uses a belt system that has no play or wear when in use for smooth manipulation.
  • It also uses a stepper motor that allows high resolution positioning and can be controlled directly by the StarGo via the AUX1 port or by the new X-MD control system that allows a stand-alone functionality thanks to the integrated battery.
SKU AV-FOCSGSO68
MANUFACTURER Avalon
  • FREE - Special Order - Contact us for shipping cost (Contact us)
