FOCs Kit Avalon for OTA Edge HD/SC 11" Celestron [AV-FOCSC11]
AV-FOCSC11
$293.59 USD
Avalon Instruments: FOCs Kit Avalon for OTA Edge HD/SC 11" Celestron: This new kit can be used ONLY with the StarGO simply connecting it to one of the the AUX port with the new focuser Ascom driver
FOCS is the new focuser for SC Celestron telescopes, easy to assemble and based on a belt system that has no play and that allows the manual focus adjustment also when the kit is mounted. FOCS is available for SC Celestron C8, C9,5 and C11 models.
The new controller FOCS uses a stepper motor that allows high resolution positioning and can be controlled directly by the StarGo via the AUX1 port or by the new X-MD control system that allows a stand-alone functionality thanks to the integrated battery.
EASY TO CONNECT
The kit can be used simply by connecting it to the door of the AUX1 Stargo using the cable supplied as standard. The FOCS have a driver ASCOM ASCOM inserted in the Stargo drivers. It will be possible then to use the FOCS with third softwares (BackyardEOS, Maxim, TheSkyX, FocusMax, Sequence Generator Pro,,etc etc).
About FOCs Kit Avalon for OTA Edge HD/SC 11" Celestron [AV-FOCSC11]
EASY TO CONNECT
SKU AV-FOCSC11
MANUFACTURER Avalon
  • FREE - Special Order - Contact us for shipping cost (Contact us)
