AstroSolar Safety Film Visual, Maximum Size 117x117cm (46"x46") ND=5 [BA-ASOLV-L]
BA-ASOLV-L
$337.00 USD
Baader: AstroSolar Safety Film Visual, Maximum Size 117x117cm (46"x46") ND=5
Baader Planetarium AstroSolar Safety Film is thoroughly processed and tested for the utmost safety and quality in observation of the Sun Baader's AstroSolar Safety Film is available at a fraction of the cost of the competitions This product is the large size sheet, at 117 cm x 117 cm Views of granulation and faculae are particularly enhanced through the use of Baader's AstroSolar Safety Film Safe for viewing the Sun, when applied correctly to your scope
Baader Planetarium's Astro Solar Film makes viewing the Sun safe and fun. The safety film projects white light views of the Sun that are unparalled to any other solar filters or material out there. Portraying fine solar detail, Baader's Astro Solar Film display penumbral detail, solar granulation, and lighter colored faculae. The film is set against a dark background, free of haze and scatter. Great performance at a great price!
Baader AstroSolar Visual Safety Film Size 117 x 117 cm presents the Sun in it's real color which is neutral white. The competition provides films and glass filters that produce a blurry bluish or reddish/orange/yellow solar image which in turn cuts part of the spectrum. With an orange Sun, it is very hard to see faculae regions which are visible predominantly in the blue wing of the spectrum. Because of AstroSolar's neutral color balance, this allows the use of various color (or interference) filters that allow observers to focus on particular spectral passbands for investigations or different layers within the solar "atmosphere".
In solar observation, eye safety is critical! Baader's AstroSolar is essentially free from pinholes because of the coating on both sides so that the chances of two pinholes overlapping each other is extremely small. While pinholes do appear the ratio is 1 out of 10,000 only, in optical density 2.5! All coatings are inspected continually for consistency and for eye safety. With Baader AstroSolar Visual Safety Film Size 117 x 117 cm, enthusiasts will enjoy the Sun's hidden grandeur at a fraction of the cost, but experiencing high quality performance in every use.
About AstroSolar Safety Film Visual, Maximum Size 117x117cm (46"x46") ND=5 [BA-ASOLV-L]
  • Baader Planetarium AstroSolar Safety Film is thoroughly processed and tested for the utmost safety and quality in observation of the Sun
  • Baader's AstroSolar Safety Film is available at a fraction of the cost of the competitions
  • This product is the large size sheet, at 117 cm x 117 cm
  • Views of granulation and faculae are particularly enhanced through the use of Baader's AstroSolar Safety Film
  • Safe for viewing the Sun, when applied correctly to your scope
  • Model Number    2459284
  • Type of Solar Equipment    Solar Film - Unmounted
  • Emission Line    White Light
  • Diameter Range    Unmounted Film
  • Solar Filter Aperture (mm)    46" x 46" sheet
  • White Light Solar Filter Material    Baader AstroSolar Safety Film
  • Solar Product Warranty    1 year
