Neutral Density Filter 1.25", Multicoated / ND 0.9 [BA-FND1-1]
BA-FND1-1
$49.00 USD
Baader: Neutral Density Filter 1.25", Multicoated / ND 0.9
Baader 1.25" Neutral Density Filter with optical density ND 0.9 - Transmission 12.5% - Reduction factor 8. For perfect energy management during Lunar and Solar observation. Suitable for solar observing only as an additional filter! If you need to reduce glare and want to use a filter ahead of the focal point (e.g. before a binocular), then the neutral density filters are just right. Fine optical polish results in no loss of sharpness at high magnifications even with a filter position 20-30cm in front of the focal point. Phantom Group coated. No ghosting, reflections or stray light. Threaded both sides of the glass allows combination with other filters (e.g. Baader Colour Filters).
About Neutral Density Filter 1.25", Multicoated / ND 0.9 [BA-FND1-1]
  • Baader 1.25" Neutral Density Filter with optical density ND 0.9 - Transmission 12.5% - Reduction factor 8.
  • For perfect energy management during Lunar and Solar observation. Suitable for solar observing only as an additional filter!
  • If you need to reduce glare and want to use a filter ahead of the focal point (e.g. before a binocular), then the neutral density filters are just right.
  • Fine optical polish results in no loss of sharpness at high magnifications even with a filter position 20-30cm in front of the focal point.
  • Phantom Group coated. No ghosting, reflections or stray light.
  • Threaded both sides of the glass allows combination with other filters (e.g. Baader Colour Filters).
  • SKU (#)    2458344
  • WEIGHT (KG)    0.06
  • NEUTRAL DENSITY    ND 0.9
  • TRANSMISSION RANGE    full Spectrum
  • AR-COATING    Phantom Coating® Group, planeoptically polished
  • TRANSMISSION    12.5%
  • DAMPING FACTOR    8x
  • FILTER SIZE    1¼"
  • VISUAL OR IMAGING?    visual, imaging
  • FILTER USAGE    Lunar, Planetary, Solar
  • TYPE OF FILTER    Neutral Density
