Baader U-Filter (Venus, Ultraviolet, ZWL 350nm), 2" [BA-FUV-2]
BA-FUV-2
$387.00 USD
Baader: Baader U-Filter (Venus, Ultraviolet, ZWL 350nm), 2"
Baader U-Filter (Venus and UV) 350nm. Transmission peak approx. 80% at 350nm, bandwidth 60nm (320-380nm), completely blocking the entire spectral range from 200nm to 1120nm. Dielectric multi-coating on optically polished Schott Glass. Enables imaging in the deep UV spectral region. A "breakthrough" for imaging the planet Venus! Allows amateur astronomers to capture cloud structures of the Venusian atmosphere. Successful astro-application of this filter requires a suitable UV-sensitive lucky imaging camera module (i.e. SKYRIS 274M) with at least a telescope of 5" diameter (a telescope with an 8" diameter is recommended). Non-astronomical applications possible: e.g. check for paint damage on cars or state of health of plants and much more.
About Baader U-Filter (Venus, Ultraviolet, ZWL 350nm), 2" [BA-FUV-2]
  • Baader U-Filter (Venus and UV) 350nm.
  • Transmission peak approx. 80% at 350nm, bandwidth 60nm (320-380nm), completely blocking the entire spectral range from 200nm to 1120nm.
  • Dielectric multi-coating on optically polished Schott Glass.
  • Enables imaging in the deep UV spectral region. A "breakthrough" for imaging the planet Venus! Allows amateur astronomers to capture cloud structures of the Venusian atmosphere.
  • Successful astro-application of this filter requires a suitable UV-sensitive lucky imaging camera module (i.e. SKYRIS 274M) with at least a telescope of 5" diameter (a telescope with an 8" diameter is recommended).
  • Non-astronomical applications possible: e.g. check for paint damage on cars or state of health of plants and much more.
  • SKU (#)    2458291
  • WEIGHT (KG)    0.061
  • TRANSMISSION RANGE    UV
  • HBW (HALFBANDWIDTH)    60nm
  • CWL (CENTRAL WAVELENGTH)    350 nm
  • FILTER SIZE    2"
  • VISUAL OR IMAGING?    visual, imaging
  • FILTER USAGE    Specialty, UV-Pass
