UV-IR-CUT / L-Filter, 50x50x3mm Square [BA-FUVIR-SQ50]
BA-FUVIR-SQ50
$219.00 USD
Baader: UV-IR-CUT / L-Filter, 50x50x3mm Square
Blocks UV below 400nm and IR above 680nm Maximum transmission, scratchproof hard coated 3 mm glass thickness non-ageing sealed coating edges
About UV-IR-CUT / L-Filter, 50x50x3mm Square [BA-FUVIR-SQ50]
  • Blocks UV below 400nm and IR above 680nm
  • Maximum transmission, scratchproof hard coated
  • 3 mm glass thickness
  • SKU (#)    2459206
  • WEIGHT (KG)    0.073
  • TRANSMISSION RANGE    420 – 680 nm
  • FILTER SIZE    50 x 50 mm
  • FILTER USAGE    IR-Cut, Luminance, UV-Cut
  • FILTER MOUNTED    Unmounted
  • TYPE OF FILTER    Bandpass
  • FILTER SHAPE    square
