Baader S-II 65x65mm Narrowband-Filter (6.5nm) – CMOS-optimized [BA-FCSIIN-SQ65]
BA-FCSIIN-SQ65
$618.28 CAD
Baader: Baader S-II 65x65mm Narrowband-Filter (6.5nm) – CMOS-optimized
65 x 65 mm x 3 mm Baader S-II Narrowband Filter – Precision Grade 6.5 nm FWHM, recommended for optical systems from f/10 to f/3.5 Reflex-Blocker™ hard coated and planeoptically polished – with sealed coating edges (Life-Coat™) Blackened edges all around, with filter-lead-side-indicator in the form of a telescope-sided black outer rim Optimized for modern CMOS cameras, but likewise excellent for CCD camera technologies SKU 2961256
About Baader S-II 65x65mm Narrowband-Filter (6.5nm) – CMOS-optimized [BA-FCSIIN-SQ65]
  • 65 x 65 mm x 3 mm Baader S-II Narrowband Filter – Precision Grade
  • 6.5 nm FWHM, recommended for optical systems from f/10 to f/3.5
SKU 2961256
  • SKU (#)    2961256
  • EAN CODE    4047825047397
  • NET WEIGHT (KG)    0.09
  • COLOUR    Black
  • TRANSMISSION RANGE    S-II
  • CWL (CENTRAL WAVELENGTH)    671,7 nm
  • FILTER SIZE    65 x 65 mm
  • FILTER USAGE    CMOS, CCD, S-II
  • FILTER MOUNTED    Unmounted
  • FILTER SHAPE    square
