Baader S-II 50x50mm Narrowband-Filter (6.5nm) – CMOS-optimized [BA-FCSIIN-SQ50]
50 x 50 mm x 3 mm Baader S-II Narrowband Filter – Precision Grade 6.5 nm FWHM, recommended for optical systems from f/10 to f/3.5 Reflex-Blocker™ hard coated and planeoptically polished – with sealed coating edges (Life-Coat™) Blackened edges all around, with filter-lead-side-indicator in the form of a telescope-sided black outer rim Optimized for modern CMOS cameras, but likewise excellent for CCD camera technologies SKU 2961255
About Baader S-II 50x50mm Narrowband-Filter (6.5nm) – CMOS-optimized [BA-FCSIIN-SQ50]
Baader: Baader S-II 50x50mm Narrowband-Filter (6.5nm) – CMOS-optimized
- 50 x 50 mm x 3 mm Baader S-II Narrowband Filter – Precision Grade
- 6.5 nm FWHM, recommended for optical systems from f/10 to f/3.5
- Optimized for modern CMOS cameras, but likewise excellent for CCD camera technologies
SKU 2961255
- SKU (#) 2961255
- EAN CODE 4047825047380
- NET WEIGHT (KG) 0.07
- COLOUR Black
- TRANSMISSION RANGE S-II
- FILTER THICKNESS (WITHOUT CELL) 3 mm
- HBW (HALFBANDWIDTH) 6.5 nm
- CWL (CENTRAL WAVELENGTH) 671,7 nm
- AR-COATING Reflex-Blocker™ hard coated, planeoptically polished
- SPECIAL FEATURES CMOS-optimized with Life-Coat™
- FILTER SIZE 50 x 50 mm
- FILTER USAGE CMOS, CCD, S-II
- FILTER MOUNTED Unmounted
- TYPE OF FILTER Narrowband
- FILTER SHAPE square
