Baader RGB Filter Set 65x65x3mm Square with UV/IR Cut L-Filter (Optically Polished) [BA-FLRGB-SQ65]
BA-FLRGB-SQ65
$949.00 USD
Baader: Baader RGB Filter Set 65x65x3mm Square with UV/IR Cut L-Filter (Optically Polished)
4 filters L-RGB Ultra high contrast impermeable RGB-Filter, IR-blocked NO halos, NO reflections, NO ghosting non-ageing sealed coating edges
About Baader RGB Filter Set 65x65x3mm Square with UV/IR Cut L-Filter (Optically Polished) [BA-FLRGB-SQ65]
  • 4 filters L-RGB
  • Ultra high contrast impermeable RGB-Filter, IR-blocked
  • NO halos, NO reflections, NO ghosting
  • SKU (#)    2458492
  • WEIGHT (KG)    0.348
  • TRANSMISSION RANGE    multiple bands (see spectral image)
  • FILTER SIZE    65 x 65 mm
  • FILTER USAGE    CCD, Contrast Enhancement, Light Pollution Reduction, Luminance, RGB
  • FILTER MOUNTED    Unmounted
  • TYPE OF FILTER    Bandpass
  • SINGLE OR SET?    Filter-Set
  • FILTER SHAPE    square
