IR-Pass Filter (685nm), 1.25" (with LPFC) [BA-FIRP-1]
Baader IR-Pass Filer HWB 685nm Reduces the effect of seeing resulting in a much sharper image. Tip for use: Ideal for imaging and used for the luminosity channel. The effect of use: The normal spectral bandwidth is 400-700nm. This filter starts at 670nm in the deep red, just in the visual range so it can be focussed correctly. At this long-wavelength spectral range the atmospheric air turbulence (seeing) has much lower impact on the sharpness. Dark structures on Mars, Jupiter the Moon and the Sun are thereby rendered much sharper. The luminosity can then be combined with RGB creating a very sharp LRGB image. Highly recommended for any planetary imager. Reflex free anti-reflective and optically polished.
About IR-Pass Filter (685nm), 1.25" (with LPFC) [BA-FIRP-1]
Baader: IR-Pass Filter (685nm), 1.25" (with LPFC)
- Baader IR-Pass Filer HWB 685nm
- Reduces the effect of seeing resulting in a much sharper image.
- Tip for use: Ideal for imaging and used for the luminosity channel.
- The effect of use: The normal spectral bandwidth is 400-700nm. This filter starts at 670nm in the deep red, just in the visual range so it can be focussed correctly. At this long-wavelength spectral range the atmospheric air turbulence (seeing) has much lower impact on the sharpness. Dark structures on Mars, Jupiter the Moon and the Sun are thereby rendered much sharper. The luminosity can then be combined with RGB creating a very sharp LRGB image.
- Highly recommended for any planetary imager.
- Reflex free anti-reflective and optically polished.
- SKU (#) 2458385
- WEIGHT (KG) 0.059
- TRANSMISSION RANGE > 685 nm
- AR-COATING dielectrically coated, planeoptically polished
- FILTER SIZE 1¼"
- VISUAL OR IMAGING? imaging
- FILTER USAGE Contrast Enhancement, IR-Pass, Planetary
- TYPE OF FILTER Bandpass
- FILTER SHAPE round
