Narrowband H-Beta Filter 8.5nm, 1.25" (with LPFC) [BA-FHBN-1]
1¼" Baader H-Beta CCD-filter 8,5nm with 1¼" (28,5mm) filter thread For focal ratios between f10 and f2.8 H-Beta-CCD-narrowband-filters can also be used for visual observations! (A high-quality alternative to the old Lumicon-H-Beta-Filters) Antireflex-coating, fineoptically polished
About Narrowband H-Beta Filter 8.5nm, 1.25" (with LPFC) [BA-FHBN-1]
Baader: Narrowband H-Beta Filter 8.5nm, 1.25" (with LPFC)
- 1¼" Baader H-Beta CCD-filter 8,5nm with 1¼" (28,5mm) filter thread
- For focal ratios between f10 and f2.8
- H-Beta-CCD-narrowband-filters can also be used for visual observations! (A high-quality alternative to the old Lumicon-H-Beta-Filters)
- Antireflex-coating, fineoptically polished
- SKU (#) 2458425
- WEIGHT (KG) 0.059
- TRANSMISSION RANGE H-beta
- HBW (HALFBANDWIDTH) 8.5nm
- CWL (CENTRAL WAVELENGTH) 486 nm
- AR-COATING dielectrically coated, planeoptically polished
- FILTER SIZE 1¼"
- VISUAL OR IMAGING? imaging
- FILTER USAGE CCD, H-Beta, IR-Cut
- TYPE OF FILTER Narrowband
- FILTER SHAPE round
