Baader H-alpha 36mm Narrowband-Filter (6.5nm) – CMOS-optimized [BA-FCHALN-RD36]
BA-FCHALN-RD36
$202.85 USD
Baader: Baader H-alpha 36mm Narrowband-Filter (6.5nm) – CMOS-optimized
36 mm x 2 mm Baader H-alpha Narrowband Filter – Precision Grade 6.5 nm FWHM, recommended for optical systems from f/10 to f/3.5 Reflex-Blocker™ hard coated and planeoptically polished – with sealed coating edges (Life-Coat™) Blackened edges all around, with filter-lead-side-indicator in the form of a telescope-sided black outer rim Optimized for modern CMOS cameras, but likewise excellent for CCD camera technologies We explicitly warn against observing the sun with a DeepSky 6.5 nm (equivalent to 65 Ångstroem) H-alpha narrowband filter, specialized solar chromosphere and prominence filters from SolarSpectrum start at 0.8 Ångstroem. Photographic experiments with a camera are theoretically possible, but by no means observe the sun with naked eyes – you endanger your eyesight!
SKU 2961102
About Baader H-alpha 36mm Narrowband-Filter (6.5nm) – CMOS-optimized [BA-FCHALN-RD36]
  • 36 mm x 2 mm Baader H-alpha Narrowband Filter – Precision Grade
  • 6.5 nm FWHM, recommended for optical systems from f/10 to f/3.5
SKU 2961102
  • SKU (#)    2961102
  • EAN CODE    4047825046932
  • NET WEIGHT (KG)    0.06
  • COLOUR    Black
  • TRANSMISSION RANGE    H-alpha
  • CWL (CENTRAL WAVELENGTH)    656,3 nm
  • FILTER SIZE    36 mm
  • FILTER USAGE    CMOS, CCD, H-alpha
  • FILTER MOUNTED    Unmounted
