Baader H-alpha 1¼" f/2 Highspeed-Filter (6.5nm) – CMOS-optimized [BA-FCHALHS-1]
BA-FCHALHS-1
$177.00 USD
Baader: Baader H-alpha 1¼" f/2 Highspeed-Filter (6.5nm) – CMOS-optimized
1¼" x 2 mm Baader H-alpha f/2 Highspeed Filter – Precision Grade – with 1¼" (28,5 mm) filter thread 6.5 nm FWHM, recommended for extremely fast optical systems from f/3.4 to f/1.8 Specially designed for the special filter requirements when used with fast optics like the Celestron RASA astrographs Reflex-Blocker™ hard coated and planeoptically polished – with sealed coating edges (Life-Coat™) Blackened edges all around, with filter-lead-side-indicator in the form of a telescope-sided black outer rim Optimized for modern CMOS cameras, but likewise excellent for CCD camera technologies Mounted in Baader Low Profile Filter Cell (LPFC) – 6 mm height SKU 2961150
About Baader H-alpha 1¼" f/2 Highspeed-Filter (6.5nm) – CMOS-optimized [BA-FCHALHS-1]
  • 1¼" x 2 mm Baader H-alpha f/2 Highspeed Filter – Precision Grade – with 1¼" (28,5 mm) filter thread
  • 6.5 nm FWHM, recommended for extremely fast optical systems from f/3.4 to f/1.8
  • Specially designed for the special filter requirements when used with fast optics like the Celestron RASA astrographs
  • Mounted in Baader Low Profile Filter Cell (LPFC) – 6 mm height
SKU 2961150
    SKU (#)    2961150
    EAN CODE    4047825047052
    NET WEIGHT (KG)    0.06
    COLOUR    Black
    TRANSMISSION RANGE    H-alpha
    FILTER THICKNESS (WITHOUT CELL)    2 mm
    HBW (HALFBANDWIDTH)    6.5 nm
    CWL (CENTRAL WAVELENGTH)    656,3 nm
    AR-COATING    Reflex-Blocker™ hard coated, planeoptically polished
    SPECIAL FEATURES    CMOS-optimized with Life-Coat™
    FILTER SIZE    1 25 inch
    FILTER USAGE    CMOS, CCD, H-alpha
    FILTER MOUNTED    Mounted (LPFC 6mm)
    TYPE OF FILTER    f/2 Highspeed
    SINGLE OR SET?    Single Filter
    FILTER SHAPE    round
