DSLR-Astro Conversion Filter ( Baader-ACF 1 ) for Canon EOS 300 improved spectral transmission! [BA-FACF-1]
BA-FACF-1
$99.00 USD
Baader: ACF DSLR Astro Conversion Filter EOS 300D
The BAADER FILTER DSLR ACP I is a DSLR correction filter for the Canon EOS300D camera. Transform your Canon DSLR into a superb deep astrophotography camera! The new Baader DSLR correction filter replaces your camera's "serial correction" filter ("hot mirror"). The special substrate is treated with Baader's renowned UV-IR-Cut treatment. Your camera can now gain all the benefits of Baader's UV / IR Cut filters, giving full efficiency to H-Alpha wavelengths, and full resolution (the Baader filter eliminates Canon's Moire Series filter which reduces resolution Of astronomical objects). The thickness of the Baader DSLR conversion filter has been designed to maintain the same focal point. Note, however, that the filter is intentionally thicker than the standard filter - this is required to have the same refractive index as the original filter. This filter is designed to be used by amateurs who are comfortable to replace the original filter of their camera.
About DSLR-Astro Conversion Filter ( Baader-ACF 1 ) for Canon EOS 300 improved spectral transmission! [BA-FACF-1]
  • SKU (#)    2459211
  • WEIGHT (KG)    0.012
  • TRANSMISSION RANGE    400 – 700 nm
  • FILTER SIZE    other
  • FILTER USAGE    Color Correction, H-alpha, IR-Cut, UV-Cut
  • FILTER MOUNTED    Unmounted
  • FILTER SHAPE    rectangular
