8lbs Stainless Steel Counterweight For .79″ Shaft [ADM-SS8CW-79]
ADM-SS8CW-79
$149.00 USD
ADM Accessories: -Stainless steel counterweight is made to fit .79″ diameter counterweight shafts.
-A bronze press-fit sleeve in the center hole prevents marring of the shaft as the weights are adjusted, and the counterweight can be locked in place with a large, recessed knob.
-Beautiful CNC machine finish which will compliment any mount with .79″ diameter counterweight shafts.
-5″ Diameter, 1.5″ Thick, Wt. is 8 lbs.
About 8lbs Stainless Steel Counterweight For .79″ Shaft [ADM-SS8CW-79]
Weight 8 lbs
Dimensions 6 x 6 x 3 in
    6 in × 6 in × 3 in
    8 lb
