D Series MINI-MAX ALT/AZ Aiming Device Upgrade For Side-By-Side System. [ADM-DSBS-MINIMAX]
ADM-DSBS-MINIMAX
$320.00 USD
ADM Accessories: -Alternative to adjustable guidescope rings.
This product is only available with the purchase of a side by side connecting bar and saddle.
-Supports guidescope/finderscope with tube rings and dovetail bar for added stability and simple adjustability.
-Used for co-aligning two optical tubes for viewing the same target or offsetting two optical tubes to find a suitable guidestar for autoguiding.
-Designed entirely for the Vixen “V” series of dovetail bars to help reduce the overall weight to under 2.1 lbs.
-Male version bolts directly to V Series or D Series connecting dovetail bars
-Capable of handling any guidescope under 10lbs.
-10 degrees of Azimuth adjustment and 5 degrees of altitude adjustment.
-6.4″ long and adds approximately 1.6″ of height (from top of dovetail on OTA to bottom dovetail on guidescope)
-CNC machined from aircraft quality 6061 aluminum. -All components are anodized aluminum and stainless steel for a beautiful finish and long lasting durability.
About D Series MINI-MAX ALT/AZ Aiming Device Upgrade For Side-By-Side System. [ADM-DSBS-MINIMAX]
Weight 2.5 lbs
Dimensions 8 x 6 x 5 in
    8 in × 6 in × 5 in
    2.5 lb
