D Series MAX Guider ALT/AZ Aiming Device Upgrade For Side-By-Side System. [ADM-DSBS-MAX]
ADM-DSBS-MAX
$425.00 USD
ADM Accessories: -Alternative to adjustable guidescope rings.
This product is only available with the purchase of a side by side connecting bar and saddle.
-Supports guidescope/finderscope with tube rings and dovetail bar for added stability and simple adjustability.
-Used for co-aligning two optical tubes for viewing the same target or offsetting two optical tubes to find a suitable guidestar for autoguiding.
-Attaches to D Series of dovetail bars, accepts D or V Series dovetail bars.
–Male version bolts directly to V Series or D Series connecting dovetail bars
-Capable of handling guidescopes under 15lbs.
-10 degrees of Azimuth adjustment and 5 degrees of altitude adjustment.
-Wt. 3.7 lbs. 7.5″ long and adds approximately 1.5″ of height (from top of dovetail on OTA to bottom dovetail on guidescope)
-CNC machined from aircraft quality 6061 aluminum.
-All components are anodized aluminum and stainless steel for a beautiful finish and long lasting durability.
About D Series MAX Guider ALT/AZ Aiming Device Upgrade For Side-By-Side System. [ADM-DSBS-MAX]
Weight 4.2 lbs
Dimensions 8 x 6 x 6 in
    8 in × 6 in × 6 in
    4.2 lb
