MAX Guider ALT/AZ Aiming Device. Male Dovetail Version [ADM-MAX-M]
-Supports guidescope/finderscope with tube rings and dovetail bar for added stability and simple adjustability.
-Used for co-aligning two optical tubes for viewing the same target or offsetting two optical tubes to find a suitable guidestar for autoguiding.
-Male version bolts directly to V Series or D Series connecting dovetail bars
-Capable of handling guidescopes under 15lbs.
-10 degrees of Azimuth adjustment and 5 degrees of altitude adjustment.
-Wt. 3.7 lbs. 7.5″ long and adds approximately 1.5″ of height (from top of dovetail on OTA to bottom dovetail on guidescope).
-CNC machined from aircraft quality 6061 aluminum.
-All components are anodized aluminum and stainless steel for a beautiful finish and long lasting durability.
About MAX Guider ALT/AZ Aiming Device. Male Dovetail Version [ADM-MAX-M]
ADM Accessories: -Alternative to adjustable guidescope rings.
Weight | 4.2 lbs |
Dimensions | 8 x 6 x 6 in |
Size8 in × 6 in × 6 in
Weight4.2 lb
