ZWO Filter Wheel (5 x 1.25'') [ZWO-FW5-125]
ZWO-FW5-125
$88.00 USD
3 in stock IN STOCK, usually ships within 48h or less directly from our Canadian warehouse
ZWO Optical: Manual 5-position 1.25"? Filter Wheel with a numbered “click” at every position to make the task a breeze.
Changing filters couldn’t be simpler. Use the best MFW you can find on market!
The ZWO manual filter wheel, designed to accommodate up to 5 31.75 mm diameter filters, attaches directly to the 31.75 mm tip of an eyepiece holder or to a T-type mount.
It is compatible with all commercial CCD cameras and DSLR cameras: the connection with your imager is made either through the 31.75 mm tube (supplied with) adaptable to most CCD cameras (ZWO, Orion, Atik, SBIG, etc ...) or by using a T2 ring screwed on the 42 mm dia. 0.75 mm pitch, such as that fitted to Starlight Xpress cameras or digital SLR cameras.
The movable turret (carousel) that can accommodate the 5 filters is manual and a click-stop system is heard when a filter is placed exactly opposite the imager, allowing a position rigorously identical to each rotation.
The filter wheel housing is made of black anodized aluminum and is robust in design to support a CCD camera or SLR camera without any bending.
Attention, filters sold separately.
About ZWO Filter Wheel (5 x 1.25'') [ZWO-FW5-125]
  • Model: Filter wheel ZWO 31,75 mm
  • Diameter of the filters: 31.75 mm (1.25")
  • Number of possible filters: 5
