125 mm Adjustable Rings With Delrin Tipped Thumb Screws [ADM-R125]
Fits V Series dovetail bars. Includes two 125mm (ID) adjustable guidescope rings with large delrin tipped thumb screws. Adjustable from 70mm – 110mm. Wt. as shown 14 oz.
About 125 mm Adjustable Rings With Delrin Tipped Thumb Screws [ADM-R125]
ADM Accessories: Pair of 125 mm finderscope rings with 3/8" aluminum screws with large 1/4" Delrin Tips for adjusting. Thoroughly made of stainless steel and anodized aluminum for maximum longevity. An ideal way to mount a guidescope to large Dobsonian rocker boxes or existing optical tube rings. Each ring features three 1/4x20 TPI holes. Center hole is fixed to a 1.25" flat base while the other two holes are each 1/2" from the center and 1" apart from each other.
Weight | .9 lbs |
Dimensions | 8 x 5 x 2 in |
Size8 in × 5 in × 2 in
Weight0.9 lb
