150 mm Adjustable Rings With Delrin Tipped Thumb Screws [ADM-R150]
About 150 mm Adjustable Rings With Delrin Tipped Thumb Screws [ADM-R150]
ADM Accessories: 150mm guidescope rings with 3/8" aluminum adjusting screws featuring large 1/4" Delrin tips. Made of stainless steel and thoroughly anodized for maximum longevity. Provides an excellent way to mount a guidescope to a large Dobsonian rocker box or OTA tube rings. Each ring has three 1/4" x 20 TPI holes. The center hole is placed over a 1.25" flat base while the others are 1/2" from the center hole and 1" apart from each other. Fits V Series dovetail bars. Includes two 150mm (ID) adjustable guidescope rings with large delrin tipped thumb screws. Adjustable from 95mm – 135mm. Wt. as shown 20 oz.
Weight | 1.5 lbs |
Dimensions | 8 x 5 x 2 in |
Size8 in × 5 in × 2 in
Weight1.5 lb
