ZWO ASI174MM Monochrome astronomy camera. 1/1.2''size 1936X1216 @164fps Mono/Color USB3.0 [ZWO-ASI174MM]
ZWO-ASI174MM
$599.00 USD
ZWO Optical: ASI174MM/MC is our new camera designed especially for Sun and Moon imaging. Our brand new ASI174MM CMOS Monochrome Imaging Camera is based on the Sony Exmor IMX174 2.35MP sensor with Pregius global shutter technology. The Sony IMX174 monochrome CMOS sensor that separates the ASI174MM from previous ASI models. This type 1/1.2” Sony CMOS image sensor, with a 5.86µm unit pixel in a 1936 x 1216 array, has a lot of advantages when taking high quality solar, lunar, planetary, and deep sky object images.Pregius Global Shutter function with analog memory permits the scanning of all pixels simultaneously.
The Sony IMX174’s global shutter function provides improved image quality by making sure images of moving objects avoid focal plane distortion. This is especially helpful when performing solar or lunar imaging. Bad seeing, wind, or movement can alter the image if the readout speed is not quick enough (< 30fps).Sony Exmor technology uses column-parallel A/D conversion for high speed processing, low noise, and low power dissipation.ROI, or Region of Interest Mode lets you capture up to 16 areas inside the effective pixels. This ability allows for even higher frame rates.High speed imaging with a max of 164.5 fps at 10 bit ADC, and max of 128.2 fps at 12 bit ADC
What’s in the box?
–ZWO ASI USB 3.0 Camera Body (not include the lens)
–M42-1.25″ nosepiece
–1.25″ Cover
–2 m long USB cable
–2 m long ST4 guider cable
–Driver & Extra Software CD (Mac, PC & Linux Compatible)
About ZWO ASI174MM Monochrome astronomy camera. 1/1.2''size 1936X1216 @164fps Mono/Color USB3.0 [ZWO-ASI174MM]
What’s in the box?
–1.25″ Cover
–2 m long USB cable
  • Width: 41 mm
  • Diameter: 62 mm
  • Sensor Type: CMOS - 12 bit Monochrome
  • Sensor size: 11.3 mm x 7.1 mm
  • Number of pixels: 1936 x 1216 pixels
  • Pixel size: 5.86 μm x 5.86 μm
  • Sensor: Sony - IMX 174 LLI / IMX 174 LQJ Monochrome
  • Number of frames per second: Up to 740 frames per second in 320 x 240 pixel resolution
  • Autoguiding: YES
  • Connection: USB 3.0 and USB 2.0
  • A / D Conversion: 12 bit
  • Cooling: NO (passive cooling)
  • Compatibility: Prism 8, FireCapture
  • Weight: 140 g
  • Flow: 31.75 mm (1.25 ") / 50.8 mm (2") / T2 (M42 x 0.75)
  • USB Cable: Length 2 m
  • Minimum exposure time: 0.000032 seconds
  • Maximum exposure time: 16 minutes
  • Power: USB
  • Computers: Windows XP, Vista, 7 and 8 (32bits / 64bits), Linux, Mac OSX
  • Quantum yield: 76%
  • Model: ZWO monochrome camera ASI174MM
