ZWO ASI120MM-S Monochrome astronomy camera. 1/3''size 1280x960 @60fps USB3.0 [ZWO-ASI120MM-S]
ZWO-ASI120MM-S
$179.00 USD
ZWO Optical: ASI120S is a super speed and sensitive USB3.0 camera. Up to 60FPS under 1280X960 full resolution. With a peak QE of 75%, beyond ICX618 and with no FPN (Fixed pattern Noise). Long time exposure supported up to 1000s. Full compatible with USB 2.0 USB Host.
The monochrome sensor of the ZWO ASI 120MM-S camera has 1.2 million pixels (1280 x 960 pixels) for use in planetary imaging and autoguiding.
In planetary mode, its resolution reaches the rate of 60 frames / second at a resolution of 1280 x 960 pixels.
This acquisition speed can be pushed to 133 fps when used in lower resolution mode (640 x 480 pixels).
For autoguiding, the camera is equipped with a standard ST4 port, adaptable to a very large number of commercial frames.
The 120MM-S UPS has a female M42 input thread, but a mechanical M42 converter to the 31.75mm and 50.8mm male connectors is supplied with the camera to fit into the eyepieces Standards of telescopes and glasses of the market.
A 2m long USB cable and a ST4 autopilot cord are also part of the package.
ZWO also offers a fish-eye lens with a focal length of 2.1 mm, enabling meteors to be captured when systematically monitoring the sky in a very large field.
What’s in the box
–ZWO ASI120MM-S Monochrome 1.2 Mega Pixel Astronomy Camera
–150° Lens Adapter for use as an all-sky camera
–M42-1.25″ nosepiece
–1.25″ IR-cut window
–2 m long USB cable
–2 m long ST4 guider cable
–Driver & Extra Software CD
About ZWO ASI120MM-S Monochrome astronomy camera. 1/3''size 1280x960 @60fps USB3.0 [ZWO-ASI120MM-S]
What’s in the box
–2 m long USB cable
  • Width: 28 mm
  • Diameter: 62 mm
  • Sensor Type: CMOS - 12 bit
  • Sensor size: 4.8 mm x 3.6 mm
  • Number of pixels: 1280 x 960 pixels
  • Pixel size: 3.75 μm x 3.75 μm
  • Sensor: CMOS MT9M034
  • Number of frames per second: Up to 254 frames per second in 320 x 240 pixel resolution
  • Autoguiding: YES
  • Connection: USB 3.0
  • Cooling: NO (passive cooling)
  • IR Filter: YES
  • Compatibility: Prism 8, FireCapture
  • Weight: 100 g
  • Flow: 31.75 mm and 50.8 mm (1.25 "and 2") and T2 (M42 x 0.75)
  • USB cable: Length 2 m
  • Minimum exposure time: 0.000064 seconds
  • Maximum exposure time: 16 minutes
  • Computers: Windows XP, Vista, 7 and 8 (32bits / 64bits)
  • Quantum yield: 75%
  • Model: ZWO monochrome camera ASI120MM- USB3.0
